Löytyisikö Lahdesta VCDS-mestaria joka haluasi 2007 B7 vikakoodit lukea?
Tässä koodit, varmaa suurin osa akun tyhjenemisestä, mutta entäs puhelinboksi? Voiko tuo vika purkaa akkua?
Monday,22,April,2013,19:41:03:20961
VCDS Version: Release 11.11.5
Data version: 20121222
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E17A273595 Mileage: 206300km/128188miles
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 H HW: 8E0 614 517 BF
Component: ESP8 FRONT H06 0140
Revision: 00000000 Serial number: 00000000000000
Coding: 0004401
Shop #: WSC 06335 000 00000
VCID: 2C5D0D078F5AD678AD4
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 6
Reset counter: 29
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4222
Hex Value: 0x0024
Hex Value: 0x0194
Hex Value: 0x0001
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenks·ulenmodul 0701
Coding: 04042
Shop #: WSC 06335
VCID: 41834CB34BD82B106E2
2 Faults Found:
01301 - Control Module for Voice Recognition (J507)
49-00 - No Communications
01303 - Telephone Transceiver (R36)
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 932 HW: 8E0 920 932
Component: KOMBI+WFS 4 H10 0200
Revision: 0200 Serial number: 00000000000000
Coding: 0006018
Shop #: WSC 31000 205 178012
VCID: E6C93F2FD236AC283B0
2 Faults Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
004 - No Signal/Communication
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 Q HW: 8E0 035 192 Q
Component: RNS-E HIGH EU H73 0650
Revision: 03S Serial number: AUZBZ7G1122985
Coding: 0301715
VCID: 3261137FAE7E8088E78
3 Faults Found:
00532 - Supply Voltage B+
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 3
Reset counter: 237
Time Indication: 0
Date: 2006.07.18
Time: 00:01:01
Freeze Frame:
Voltage: 13.00 V
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 237
Time Indication: 0
Date: 2013.04.14
Time: 10:03:18
Freeze Frame:
Voltage: 13.00 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 174
Time Indication: 0
Date: 2006.07.18
Time: 02:30:55
Address 46: Central Conv. Labels: None
Part No: 8E0 959 433 CN
Component: Komfortger·t TA7 4236
Coding: 07008
Shop #: WSC 06335
VCID: 7F070A4B7DAC9DE0586
Subsystem 1 - Part No: 8E1959801H
Component: T?rsteuer.FS BRM 0606
Subsystem 2 - Part No: 8E1959802H
Component: T?rsteuer.BF BRM 0606
3 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
00955 - Key 1
35-10 - - - Intermittent
00956 - Key 2
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0301715
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 237
Time Indication: 0
Date: 2006.07.18
Time: 00:01:01
Freeze Frame:
Voltage: 13.00 V
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 237
Time Indication: 0
Date: 2013.04.14
Time: 10:03:18
Freeze Frame:
Voltage: 13.00 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 174
Time Indication: 0
Date: 2006.07.18
Time: 02:30:55
End ---------------------------------------------------------------------
69 75 76 77
Coding: 0004401
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 29
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4222
Hex Value: 0x0024
Hex Value: 0x0194
Hex Value: 0x0001
Coding: 04042
Shop #: WSC 06335
2 Faults Found:
Coding: 0006018
2 Faults Found:
Coding: 0301715
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 237
Time Indication: 0
Date: 2006.07.18
Time: 00:01:01
Freeze Frame:
Voltage: 13.00 V
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 237
Time Indication: 0
Date: 2013.04.14
Time: 10:03:18
Freeze Frame:
Voltage: 13.00 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 174
Time Indication: 0
Date: 2006.07.18
Time: 02:30:55
Coding: 07008
Shop #: WSC 06335
3 Faults Found:
00955 - Key 1
00956 - Key 2
Coding: 0301715
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 237
Time Indication: 0
Date: 2006.07.18
Time: 00:01:01
Freeze Frame:
Voltage: 13.00 V
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 237
Time Indication: 0
Date: 2013.04.14
Time: 10:03:18
Freeze Frame:
Voltage: 13.00 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 174
Time Indication: 0
Date: 2006.07.18
Time: 02:30:55
