Audi A8 4.2L 2004..Olisko kellään kokemusta samanlaisesta viasta?Eli auto purkaa akun yhdessä yössä.Akku on uusi ja koodattu.Apua=)
A8 akku purkautuu
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 Q HW: 4E0 907 560
Component: 4.2L V8/5V G 0030
Revision: 00000000 Serial number: AUX3Z0D1334589
Coding: 0011773
Shop #: WSC 00859 400 87080
VCID: 2F6DF537BEE897663D9-807A
2 Faults Found:
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
17985 - Right Engine Mount Solenoid Valve (N145)
P1577 - 004 - Open Circuit
Readiness: 0010 1001
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 C
Component: FBS AUDID3 H04 0140
Revision: 01404004 Serial number: AUX3Z0D1334589
Coding: 0409600
Shop #: WSC 00007 521 06508
VCID: D8BFEEEB6BE630DE0C3-808D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 4
Fault Frequency: 0
Reset counter: 96
Mileage: 173728 km
Time Indication: 0
Date: 2015.01.15
Time: 23:16:38
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 820 043 B
Component: KLIMAAUTOMAT 016 0240
Revision: 00000023 Serial number: 00000000037643
Coding: 1216595
Shop #: WSC 02311 785 00200
VCID: DABBF4E315EA22CE3A7-808F
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H02 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO14022004065A000000000005ÿ†89
Subsystem 5 - Serial number: 000005ÿ†898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO13022004065A00000000
Subsystem 7 - Serial number: 65A000000000349ÿ
1 Fault Found:
00066 - Rear Right Footwell Heater (Z43)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 96
Mileage: 173733 km
Time Indication: 0
Date: 2015.01.15
Time: 22:58:52
Freeze Frame:
Voltage: 13.80 V
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0409600
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 96
Mileage: 173728 km
Time Indication: 0
Date: 2015.01.15
Time: 23:16:38
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040402050295
Coding: 0000632
Shop #: WSC 02313 785 00200
VCID: 275D1D179618CF26F59-8072
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H03 0020
3 Faults Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 1
Mileage: 159053 km
Time Indication: 0
Date: 2003.10.08
Time: 19:29:01
Freeze Frame:
Fault Priority: 3
Reset counter: 1
Mileage: 159053 km
Time Indication: 0
Date: 2003.10.08
Time: 19:29:01
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 P HW: 4E0 035 223 A
Component: DSP-Amp.-High H00 0460
Revision: ¸À
¨À™ Serial number: ¨ÈÚ
Coding: 0000016
Shop #: WSC 65536 642 00000
VCID: 2A5BE423850AF24EEA7-807F
1 Fault Found:
02084 - Component Protection
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 83
Mileage: 166087 km
Time Indication: 0
Date: 2014.05.03
Time: 17:47:49
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000531
Shop #: WSC 49004 657 99021
VCID: 204F060BF336381EB43-8075
1 Fault Found:
02596 - Rear Brake Pads Worn
008 - Implausible Signal
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 67
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
Voltage: 8.49 V
Count: 61
End ---------------------------------------------------------------------
tuommosta kuulkaas pukkas tulemaan=)Viimeksi muokannut okkim; 16.1.2015, 23:23. Perustelu: Älä tee heti uutta viestiä perään, vaan editoi vanhaa.
Ainakin muutama tapaus on ollut missä hälytin syö virtaa reilusti ja sullahan on vikakoodikin hälystä.
Otapas hälyttimen johto irti.Tietysti yleismittarilla voisi mittailla virrankulutusta..
Eikö virranhallinta boksista tullut vikakoodia vaikka akku mennyt tyhjäksi,vai eikö siihen pääse käsiksi vcds:llä?
ddress 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000010907
Shop #: WSC 00000 000 00000
Subsystem 1 - Part No: 000 915 105 AK
Component: von TU3 1401310010
Coding: 303030393135313035414B54553331343031333130303130
Shop #: WSC 00859 400 83096
No fault code found.
onko se tuo se,,ja missähän se hälytinjohto sijaitsee?
