Auton boksi takkuili taas tänään ja pimeni kesken ajon. Boksia koputtelemalla sain sen käyntiin ja hain kotoa varaboksin mukaan. Yritin löytää haulla täältä noita koodausohjeita boksin vaihtoon, mutta en niitä kuitenkaan löytänyt. Ross-Techin sivuilta löytyi tällaiset ohjeet Immo-2:seen:
The immobilizer will prevent the car from running without a matching key microchip. There is a symbol in the instrument cluster showing a key inside a car. If a new (or different ECU) is installed in the vehicle, the immobilizer will prevent the car from running and will cause the symbol to flash. Here is the procedure to introduce a new ECU to the instrument cluster. This must be performed each time ECU's are exchanged. This does not apply to installing a "chip" in the same ECU that is already aligned with the car.
Immo-3 knows your car's VIN. Access 17-Instruments (or separate 25-Immobilizer on vehicles that are set up that way) and look at the first "Extra" field.
If you see something like: "Immo-ID VWZ7Z0W0648696" You've got Immo-2 (or maybe even Immo-1 in earlier non-US models).
If you see something like "WVZKB58001H231169 VWZ7Z0W0648696" You've got Immo-3. The first 17-digit string is the VIN. The second 14-digit string in the Immo-ID.
- Install the new ECU in the car
[Select]
[17 - Instruments]
[Adaptation - 10]
Leave channel at "00"
[Read]
[Save] - [Done, Go Back]
[Close Controller, Go Back - 06]
[Exit] - Turn ignition OFF for 15 seconds. Start vehicle.
