Morjens,
C7 ruvennut ajossa vilkuttamaan hehkun merkkivaloa n.500km välein. vikakoodiksi tulee P0234. -> limp
Auton uudelleenkäynnistys kuittaa vian ja auto toimii taas normaalisti.
Näkeekö tuosta suoraan, mikä mahtaisi olla vialla? Asennoittimen alle 1%.n heittoko tuon tekee?
1 Fault Found:
5172 - Boost Pressure Regulation
P0234 00 [096] - Limit Exceeded (Overboost Condition)
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 10
Mileage: 145186 km
Date: 2021.12.17
Time: 05:28:34
Engine RPM: 1787.50 /min
Normed load value: 40.0 %
Vehicle speed: 57 km/h
Coolant temperature: 55 °C
Intake air temperature: 8 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 14.380 V
Unlearning counter according OBD: 40
Charge Pressure Actuator: activation: 70.54 %
Charge air pressure actuator: acknowledgment: 69.84 %
Ambient temperature: 1.0 °C
Charge air pressure: specified value: 1422 hPa
Accelerator pedal travel: 27.11 %
Air mass: actual value (mg/stroke): 871.1 mg/stroke
Actual charge pressure: 1678 hPa
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Mileage: 145186 km
Date: 2021.12.17
Time: 05:28:34
