Mistä VIN-dekooderi joka kertoo..
  • Mistä VIN-dekooderi joka kertoo..
    autosta kaiken?
    Lisävarusteita myöten..
    Tuolla jotain aiheesta:
    http://www.audiclub.fi/audifinns/sho...&highlight=VIN
      Joo tuo topic tuli plärättyä mutta nuo linkit ovat vainaita..
        PRCode: 0G7 = Tiptronic
        PRCode: 0GZ = emissions concept EU 3
        PRCode: 0JG = weight category front axle weight range 7
        PRCode: 0YH = weight category rear axle weight range 8
        PRCode: 1BE = sports suspension/shock absorption
        PRCode: 1KD = disc brakes, rear
        PRCode: 1LB = disc brakes, front
        PRCode: 1N1 = power steering
        PRCode: 1SA = without additional engine guard
        PRCode: 2PV = leather trimmed sports steering wheel
        PRCode: 3FA = without roof insert (standard roof)
        PRCode: 3L3 = manual height adjustment for front seats
        PRCode: 3NZ = rear seat bench unsplit, backrest split folding
        PRCode: 3Y0 = without roll-up sun screen
        PRCode: 4GH = windshield tinted with windshield sunshield
        PRCode: 4K4 = radio remote controlled central locking operated from inside and separate trunk release
        PRCode: 4KC = side and rear windows tinted
        PRCode: 4R5 = power windows with comfort operation andcircuit breaker, mechanical window regulators rear
        PRCode: 4UE = airbag f. driver a. front seat passenger
        PRCode: 4X3 = side airbag front with curtain airbag
        PRCode: 5D1 = carrier frequency xxx.xx MHz
        PRCode: 5MA = decorative inserts
        PRCode: 5RU = outer right rear view mirror: convex (large viewing field)
        PRCode: 5SL = outer left rear view mirror: non-spherical
        PRCode: 6R0 = selector lever cover
        PRCode: 6XJ = outer rear view mirrors: powered, heatedautomatically dimming
        PRCode: 7A0 = without CD changer/CD player
        PRCode: 7K0 = without tire pressure warning light
        PRCode: 7X0 = without park distance control
        PRCode: 7Q0 = without navigation device
        PRCode: 8ED = bi-functional headlight with gas discharge lamp, for driving on the right
        PRCode: 8GU = alternator 140A
        PRCode: 8Q3 = automatic headlight-range adjustment dynamic (self-adjusting while driving)
        PRCode: 8Z5 = engine cooling system, type 1
        PRCode: 9Q3 = multi-function indicator, without on-board computer and check control
        PRCode: C1X = alloy wheels 7 1/2J x 17 five-arm spider style, offset 45
        PRCode: D3E = 4-cyl. turbo diesel engine 1.9 L/96 kW TDI with pump-jet injection system, EU 3base engine is T9J/TG0
        PRCode: E0A = no special edition
        PRCode: F0A = no special purpose vehicle, standard equipment
        PRCode: J1D = battery 380 A (72 Ah)
        PRCode: Q1D = sports front seats
        PRCode: T9J = components for base engine, unit 038.K
        PRCode: U1A = instrument insert with km/h speedometer,clock, tachometer and trip odometer
        PRCode: VJ1 = reinforced bumpers
        PRCode: X0A = national sales program Germany
        Mun autossa...
        Tosin jälkikäteen laitettu vakionopeudensäädin ja ajotietokone.
        Itse täytyy näppäillä lisävarustelista... :p
        http://prsearch.planetvag.com/default.aspx
        Viimeksi muokannut diexsel; 2.6.2009, 12:47. Perustelu: lisäys
          Mistä saan tietää PR-codeni?
            Autossa ja huoltokirjassa olevasta tarrasta.
              vin dekooderi löytyy myös http://my.audi.com sivulta, vaatii rekisteröitymisen
                Alkuperäinen kirjoittaja JariT Näytä viesti
                itsellänikin ennen näytti tuolla kaikki varusteet mitä autossa tehtaalta lähtiessään on, mutta ei anna enää mitään tietoja. Onkos tuonne tullut joku uusi "juttu" vai onko database vaan ollut "rikki" jo pidemmän aikaa eli tietoja ei enää tuolta ilmaiseksi näe.
                  Saiko tuota sivua jotenkin englannin kieliseksi? Mulla meni automagisesti saksankieliseksi. No kyllähän tuokin jonniinverran taipuu (täytyyhän sitä Audi-miehen sitä osata :-) mutta englanti toimis paremmin.
                    Jotain lisävarusteista täälläkin:
                    http://www.a4avanti.de/CodA4.htm
                      http://igorweb.org/equidec/Default.aspx tuossa vielä yksi joka ei vaadi rekisteröitymistä
                        3FQ = electric sliding/pop-up sun roof with automatic pre-selection
                        Mitä tuo "automatic pre-selection" tässä yhteydessä tarkoittaa?
                          Googlailulla jossain jotain tuollaista kuvailtiin ja arvauksena siitä se ilmeisesti on ominaisuus millä moottori osaa palauttaa automaattisesti esivalittuun kohtaan. Ts. asentomuisti kattoikkunalle?
                            Tuolla tarkoitetaan sitä että voi valita luukun asennon sillä säätöpyörällä. Vanhemmissa malleissa (pre -93?) on vain se keinukytkin jota pitää painaa koko ajan kun haluaa luukun liikkuvan.
                              Tässä pari, eivät kyllä kerro ihan kaikkea.
                              http://passat.stoynev.us/misc_tech/vin.php
                              http://s87762315.onlinehome.us/vin.php?site=vw
                                Mistäköhän coupesta löytää nuo tähän täytettävät koodit? http://prsearch.planetvag.com/default.aspx
                                Kun huoltokirja on tippunut matkalle.
                                  Paksin pohjasta mattojen alta? Sieltä ainakin omasta urssista löytyi.
                                    Takakopasta hanttimienhen puolisesta kulmasta muovisen kaukalon takaa (alla sen luukun ja muovikaukalo pois).
                                      MyAudi-sivusto toimii ja antoi itse asiassa yllättävän tarkan listan ainakin tuon oman S6:n vakio- ja lisävarusteista.
                                        http://prsearch.planetvag.com/default.aspx Toimii ja helppo käyttää.
