Transporterin boksi vaihtoon?
  • Transporterin boksi vaihtoon?
    Tällaista koodia pukkaa:
    Tuesday,24,February,2015,17:02:40:26988
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 14.10.0.0
    Data version: 20141022
    VIN: WV1ZZZ7HZ4H096658 License Plate:
    Mileage: 240820km-149638mi Repair Order:
    Chassis Type: 7H (7H - VW Transporter/Multivan (2003 > 2010))
    Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
    57 6E 76 77 78 7D
    VIN: WV1ZZZ7HZ4H096658 Mileage: 240820km-149638miles
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 038 906 016 HW: 028 101 073 4
    Component: R4 1,9L EDC 5225
    Shop #: WSC 02756 785 00200
    VCID: 51A34D79CB8056A9B05-515C
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 03: ABS Brakes Labels: 7H0-907-37x-ASR-F.lbl
    Part No: 7H0 907 379 E
    Component: ASR FRONT MK25 0103
    Coding: 0007206
    Shop #: WSC 80093 222 69422
    VCID: 377713E14524E8999E1-5122
    2 Faults Found:
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    004 - No Signal/Communication
    Address 09: Cent. Elect. Labels: 7H0-937-049.lbl
    Part No: 7H0 937 049 J
    Component: BORDNETZ SGVER 1.0 0901
    Coding: 0000037
    VCID: 397315D97330FEE9685-5122
    2 Faults Found:
    01299 - Diagnostic Interface for Data Bus (J533)
    01341 - Control Module in Instrument Panel On Comfort CAN (J285)
    008 - Implausible Signal
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 1C0 909 605 A
    Component: 3B AIRBAG VW51 0008
    Coding: 13122
    Shop #: WSC 02756
    VCID: 2241D2B5AEA69D3159F-5122
    1 Fault Found:
    00532 - Supply Voltage B+
    07-10 - Signal too Low - Intermittent
    Address 17: Instruments Labels: 7Hx-920-xxx-17.lbl
    Part No: 7H0 920 850 R
    Component: KOMBI+WEGFAHRSP VDO V01
    Coding: 03111
    Shop #: WSC 42400
    VCID: 397315D92330FEE9685-5122
    WV1ZZZ7HZ4H096658 VWZ7Z0D9594918
    2 Faults Found:
    01176 - Key
    49-00 - No Communications
    Address 18: Aux. Heat Labels: 7H0-819-008.lbl
    Part No: 7H0 815 071 C
    Component: Standheizung 0207
    Shop #: WSC 00000 000 00000
    VCID: 2855C09D989A776107B-5122
    3 Faults Found:
    00664 - Fuel gauge
    002 - Lower Limit Exceeded - Intermittent
    01126 - Engine Speed Signal
    02085 - Incorrect Control Module Installed
    000 - -
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 02737
    VCID: 70E5E8FD30CA7FA19FB-5122
    1 Fault Found:
    Address 46: Central Conv. Labels: 7H0-959-433.lbl
    Part No: 7H0 959 433 B
    Component: Komfortgerát 0004
    Coding: 00024
    Shop #: WSC 02756
    VCID: 326122F5FE460DB1A9F-4B1C
    No fault code found.
    End-------------------------(Elapsed Time: 06:45)--------------------------
    Ja akussa virtaa ihan ok?
      Lähteekö käyntiin? Sulakkeet ehjät?
        Sulakkeet ehjät, ei lähde käyntiin ei. Akku ok. tuo B+ vikakoodi poistuu nollaamalla. Muut ei.
        CAN -väylää mittailtu mutta ei tuloksia diagnostiikka pistokkeesta mitattuna, moottorinohjainlaitteelta mitattuna CAN+ maata vasten on jännite mutta signaali-maata vasten ei ??
        Viimeksi muokannut evinrude; 27.2.2015, 18:49. Perustelu: Lisätty
          Moottorin ohjainlaite osoittautui vialliseksi, vikaa etsitään. Toisella ohjainlaitteella toimii.
