Eli isukin -01 AVB passat anto tällästä vikaa:
Address 17 -------------------------------------------------------
Controller: 3B0 920 827 A
Component: KOMBI+WEGFAHRSP VDO V05
Coding: 05115
Shop #: WSC 00000
WVWZZZ3BZ2E251830 VWZ7Z0A4303809
1 Fault Found:
01336 - Data Bus for Comfort System
80-10 - Single-Wire Operation - Intermittent
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00004
Shop #: WSC 05314
2 Faults Found:
01333 - Door Control Module: Rear Left (J388)
49-10 - No Communications - Intermittent
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 B
Component: 6Y Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 00380
1 Fault Found:
80-00 - Single-Wire Operation
End -------------------------------------------------------
Mistähän mahtaa olla kyse?
Coding: 05115
Shop #: WSC 00000
1 Fault Found:
Coding: 00004
Shop #: WSC 05314
2 Faults Found:
Coding: 00259
Shop #: WSC 00380
1 Fault Found:
