Yhtäkkiä mittaristosta hävisi taustavalot ja mikään yksittäinen mittari ei toimi. Ainoastaan ne pienet merkkivalot palaa ja isolla punaisella näytöllä toimii kaikki muut paitsi lämpötila ei tule enää näkyviin. Ajotietokonetta ei ole. VAGCOM antaa tällaisen virhekoodilistan:
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 3B0 907 552 AN
Component: 2.4L V6/5V G 0001
Coding: 11001
Shop #: WSC 06435
WAUZZZ8DZ1A079878 AUZ5Z0Y9025031
4 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16687 - Cylinder 3 Misfire Detected
P0303 - 35-10 - - - Intermittent
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 AM
Component: ABS 5.3 FRONT D20
Coding: 0273004282
Shop #: BB 24548
1 Fault Found:
00285 - ABS Wheel Speed Sensor: Front Right (G45)
Address 08 -------------------------------------------------------
Controller: 8D0 820 043 N
Component: A4 KLIMAA
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 920 900 T
Component: KOMBI+WEGFAHRS. M73 D52
Coding: 00162
Shop #: WSC 00000
No fault code found.
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35 -------------------------------------------------------
Controller: 8D0 862 257 C
Component: ZV-Pumpe D14
Coding: 02049
Shop #: WSC 06435
4 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
01365 - Lock/Unlock Switch: Interior
29-00 - Short to Ground
00991 - Interior Lights
28-00 - Short to B+
End -------------------------------------------------------
Paljon on rivejä mutta mitään varsinaista vikaa ei ollut havaittavissa ennen kuin luki virhekoodit :( Onkos kenelläkään hyviä vinkkejä mistä lähtis vikaa etsimään tuon mittariston suhteen ihan ekaksi. Onko joku sulake jossain hyvässä jemmassa?
Coding: 11001
Shop #: WSC 06435
4 Faults Found:
Coding: 0273004282
Shop #: BB 24548
1 Fault Found:
Coding: 00162
Shop #: WSC 00000
No Faults Found
Coding: 02049
Shop #: WSC 06435
4 Faults Found:
35-00 - -
35-00 - -
28-00 - Short to B+
