Ilmastoinnin alta löytyy tällänen lista vikakoodeja, mistäköhän pitäisi ratkaisua etsiä?
VAi voiko jälkiasennettu Webasto saada aikaan tälläsiä koodeja? Jos toi kellon aika pitää paikkansa niin autossa on silloin ollut Webasto päällä, ei moottori.
5 Faults Found:
00218 - Humidity Sensor (G355)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 6
Reset counter: 227
Mileage: 157888 km
Time Indication: 0
Date: 2017.11.09
Time: 07:39:53
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 2
Fault Frequency: 6
Reset counter: 227
Mileage: 157888 km
Time Indication: 0
Date: 2017.11.09
Time: 07:39:55
Freeze Frame:
Temperature: -48.0°C
Temperature: 5.0°C
Load: 0.0 %
Temperature: -55.0°C
RPM: 0 /min
Absolute Pres.: 1.0 bar
Current: 0.000 A
Temperature: 8.0°C
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 227
Mileage: 157888 km
Time Indication: 0
Date: 2017.11.09
Time: 07:39:55
Freeze Frame:
OFF
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 6
Reset counter: 227
Mileage: 157888 km
Time Indication: 0
Date: 2017.11.09
Time: 07:39:59
Freeze Frame:
Temperature: 8.0°C
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 227
Mileage: 157888 km
Time Indication: 0
Date: 2017.11.09
Time: 07:39:59
5 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 227
Mileage: 157888 km
Time Indication: 0
Date: 2017.11.09
Time: 07:39:53
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 227
Mileage: 157888 km
Time Indication: 0
Date: 2017.11.09
Time: 07:39:55
Freeze Frame:
Temperature: 5.0°C
Load: 0.0 %
RPM: 0 /min
Current: 0.000 A
Temperature: 8.0°C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 227
Mileage: 157888 km
Time Indication: 0
Date: 2017.11.09
Time: 07:39:55
Freeze Frame:
OFF
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 227
Mileage: 157888 km
Time Indication: 0
Date: 2017.11.09
Time: 07:39:59
Freeze Frame:
Temperature: 8.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 227
Mileage: 157888 km
Time Indication: 0
Date: 2017.11.09
Time: 07:39:59
