Vedossa 2 vaihteella.
1.8t agu kuluttaa liikaa
Ekös toi MAF-arvo ole aivan kohdallaan vakio koneelle:
http://wiki.ross-tech.com/wiki/index.php/Fuel_Trim_Info :
Your peak airflow should be roughly 0.80 times your horsepower if you are close to sea level. So, if you have a stock 150 hp 1.8T, expect around 120 g/s. If you see significantly less than that, you MAF may be on the way out.
