Eli palaa TPMS, Air suspension fault, headlight range fault, esc fault,parking brake vikavalot. mistä nämä voi johtua?
Akku vaihdettu vikojen jälkeen ja koodattu.
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 L HW: 4G0 907 379 L
Component: ESP PREMIUM H09 0450
Revision: -------- Serial number: --------------
Coding: 27A6DF01E465FB80FB00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 004039
ROD: EV_ESPPremiAU57X_004_AU57.rod
VCID: 3A2D24F55CDE824A517-806E
9 Faults Found:
0055 - Function Restricted due to Missing Message(s)
U1111 00 [00001001] - -
[ComScl_PDU_Fahrwerk_02_Timeout]
Confirmed - Tested Since Memory Clear
0657 - Function Restricted due to Missing Message(s)
[ComScl_PDU_Fahrwerk_03_Timeout]
0518 - Function Restricted due to Missing Message(s)
U1111 00 [10001001] - -
[ComScl_PDU_SARA_06_Timeout]
MIL ON - Confirmed - Tested Since Memory Clear
0785 - Function Restriction due to Faults in Other Modules
U1113 00 [00001001] - -
[SCL_LWR_Hoehenwert_VL_Error]
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CF HW: 4H0 907 063 F
Component: BCM1 2.0 H12 0130
Revision: 20012002 Serial number: 00000001784142
Coding: 2600E01040749FE08981008300001D0CCF9CE7082E09020100 0004606101
VCID: 6E85D8A550961EEABDF-803A
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 130909 H36 0080
Serial number: 130924160745
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 21800964
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Serial number: 27 09 2013 00000527
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: 2218CEC6000000000001
1 Fault Found:
00471 - Control Module for Elect. Regulated Dampers (J250)
004 - No Signal/Communication
Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG00F0JH3 Dataset Number: 4G0909602H 0002
Coding: 3032343631334E303431554A304C34473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
VCID: 363530C568C6662AB5F-8062
Crash sensor for side airbag: driver side:
Serial number: 3575HRB401G50LNG4935
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3585HRB400M50J5QGHS3
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 3515JRB405F2861ED1S$
Passenger side rear thorax airbag crash sensor:
Serial number: 3525JRB401250N8KFA4Z
Crash sensor for front airbag: driver side:
Serial number: 3554VRB400O50NQQ81TH
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB400M50NQQQ8U%
3 Faults Found:
1049093 - Databus
U1123 00 [00001001] - Received Error Message
[CAN: 0x101 ESP_02 error value ESP_Querbeschleunigung]
1049094 - Databus
[CAN: 0x101 ESP_02 error value ESP_Laengsbeschleunigung]
1049095 - Databus
[CAN: 0x101 ESP_02 error value ESP_Gierrate]
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4G0 907 468 AD HW: 4G0 907 468 AC
Component: J533--Gateway H13 0050
Revision: -------- Serial number: 00000001118221 Dataset Number: 4G0909515H 0067
Coding: 00CD077D00
GVL: FDA3F900DE65600D0000
ASAM Dataset: EV_GatewPkoUDS 001019
ROD: EV_GatewPkoUDS_001_AU57.rod
VCID: 72BDCCD5442E3A0A597-8026
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 3577501403
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 1307120000000000071A
4 Faults Found:
4224 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [00001000] - -
Intermittent - Confirmed - Tested Since Memory Clear
5014 - Ride Level Control Module
U0132 00 [00001001] - No Communications
6655 - Sensor electronics control module
U1077 00 [00001000] - No communication
0274 - FlexRay-Data bus
U1048 00 [00001000] - defective
[Konzern-Datenbus Flexray defekt]
Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 02018264747464545425363E00
VCID: 7CA1E2ED16EA7C7A03B-8028
1 Fault Found:
03455 - Function Restriction due to Faults in Other Modules
000 - -
Address 34: Level Control
Cannot be reached
Address 3B: Sensor Elect.
Cannot be reached
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 G HW: 4H0 907 801 A
Component: EPB-4 H03 0014
Revision: -------- Serial number: 00000000844080 Dataset Number: 4G0909522D 0007
ASAM Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_VW51.rod
VCID: 2C0112ADA68A2CFAD3B-8078
2 Faults Found:
459264 - Function Restriction due to Faults in Other Modules
U1113 00 [10001001] - -
[FC_SIGNAL_ESP_LAENGSBESCHL_ERROR_VALUE]
463616 - Function Restriction due to Faults in Other Modules
[FC_SIGNAL_ESP_QBIT_LAENGSBESCHLEUNIGUNG_QBIT]
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Component: ....LWR12.... H02 0010
Serial number: 131009-0004-044
Coding: 11226F101002A300
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic.rod
VCID: 2D071FA99D9025F2C45-8078
1 Fault Found:
120580 - Function Restricted due to Missing Message(s)
[Timeout CAN-Message Fahrwerk_01_FR (0x108)]
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 666 K HW: 4G0 035 666 H
Component: H-BN-EU H51 0732
Revision: -------- Serial number: 189J/0D7561211
Coding: 050100010003F3ED0590AB3E00000003E00001020000000000
VCID: 303906DD8A22481AEF3-8064
Subsystem 1 - Part No: 8R0 060 884 BC
Component: EUR 2013/2014 1603
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Serial number: AUZ8ZDDD002PXKM
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
Component: E380 BDT C7 H11 0204
Serial number: 90349MJ4000HE
Subsystem 4 - Part No: 8R0 060 961 F
Component: CD-Database 5298
2 Faults Found:
03157 - Functionality limited due to Communications Disruption
000 - - - Intermittent
03278 - Functionality Limited due to Missing Messages
9 Faults Found:
Coding: 0045F7
Coding: 02006D
1 Fault Found:
3 Faults Found:
1049093 - Databus
1049094 - Databus
1049095 - Databus
Coding: 00CD077D00
Voltage stabilizer:
4 Faults Found:
Revision: AA001002
1 Fault Found:
000 - -
Cannot be reached
Cannot be reached
2 Faults Found:
1 Fault Found:
2 Faults Found:
