Original K04 turbos made hybrid by FIN-turbo OY - 1500€
034motorsport K04 intake pipes - 300€
034motorsport metal WMI pipes - 200€
034motorsport phenolic spacers 2.7BIT - 60€
Gearbox mounts verkline track hardness - 120€
Rear diff mount verkline track hardness - 200€
JXB propshaft mount (will include lots of spare bushings, not shown on image) - 300€
Aquamist water methanol injection (will include various size injectors and 5L original tank) - 600€
Maxxecu Race ECU with 2x wideband lambda sensors, 2x EGT sensors, bosch fuel pressure sensor, S4 B5 wiring adapter - 1500€
S4 B7 0A3 gearbox working 100% (can include propshaft and gearbox mounts made for B5) - 800€
2.7BIT BES longblock with maxpeedingrods conrods, ARP bolts for block and conrods, mahle piston rings and crankshaft bearings, few months old bosch starter, 1 year old Denso AC compressor - 700€
RNS-E Mk2 with A6 C5 faceplate - 500€
Custom 1-mass flywheel with SRE clutch and SRE 707 clutch plate - 500€
Bosch 980cc injectors with custom injector rails and AN6 PTFE hose - 250€
Steering wheel with correct airbag for B5 and with ECUs that are needed for MFSW - 400€
Possible to pick-up in person Tallinn, Estonia
Smaller things can be sent with Omniva or Smartpost
Whatsapp: +372 5223500
