Fromin A7 2016 comp
    Voin olla väärässä, mutta oletan olevani oikeassa. Viestin #58 linkit käsittelevät VW EA897evo moottoria (CRTD etc) ja BiTDI:t ovat EA896G2. EA897evossa on vaihtuvatilavuuksinen öljypumppu mitä EA896G2:ssa ei ole.
    Toki joskus saksanfoorumilta luin että BiTDI:stä on kampiakselienkin laakereita mennyt.
    VW EA897 - Wikipedia, the free encyclopedia
    EA897evo (since 2014)
    Technology
    In 2014, a revised version of the 3.0 TDI engine was introduced. The output of the basic version has been increased from 150 kW to 160 kW and that of the high-performance version from 180 kW to 200 kW. The geometric compression ratio has been reduced to 16.0:1. The cylinder crankcase is still made from GJV-450 in sand casting and is 1.1 kg lighter than its predecessor. The engine now features a GTD 2060 VZ exhaust gas turbocharger with electromechanical VTG control. In the 200 kW version, the engine weighs 192 kg according to DIN standards.
    Significant changes concern the exhaust gas aftertreatment in order to be able to meet the Euro 6 emission standard. For example, the monoturbo variant now has a diesel oxidation catalytic converter located in the inner V of the engine, followed by a downdraft mixer to add the urea solution AdBlue, which is required to purify the nitrogen oxides. After a short mixing period, a near-engine, SCR-coated diesel particulate filter (sDPF) follows. There is also an SCR locking catalytic converter on the underbody of the vehicle.
    The chain drive has also been redesigned, and the second chain is now exclusively responsible for driving the high-pressure fuel pump. A third chain at the front of the engine takes over the drive of the new, fully variable oil pump and the vacuum pump.
    Problems with the camshaft occur more frequently with engines with the engine code letter CRTD, even with low mileages far below 100,000 km, this stage of development leads to increased wear on the tooth flank clearance compensation. Occasionally damage to the connecting bearings was reported.​
    Viimeksi muokannut andre_; 24.6.2026, 00:50.
      Kiitos tarkennuksesta Antti, olin aivan varma että tämä ominaisuus liittyi myös fl bitdi-koneisiin (CVUA&CVUB).
        Nyt alkoi CVZA miestäkin kiinnostamaan, se lie kuuluu samaan EA897 Evo perheeseen. Tämä lienee softalla korjattavissa oleva asia? Vaikka saastelaitteiden puukotus onkin jumalan murhaamisesta seuraava rikos, eikä välttämättä järjestyksessä alaspäin.
          Olen laittamassa Crafteria myyntii ja ajattelin ostaa Amarok V6. Hyvää infoa siihenkin liittyen tullut tässä porukalta. Iso kiitos infosta!
          Edelleen olen S7 tekniikanvaihdon kannalla, katsotaan tulenko vielä järkiini.
          Löytyi swappi guide DL501 -> tippi: https://www.audizine.com/threads/c7-...-guide.998086/
          Melkoista turaamista on, mutta mielenkiintoista.
          Ihmettelen tuota, ettei euromallin bittiloota kävisi.
          ”Transmission: ZF8HP55 (Any trans code from C7/C7.5 or D4/D4.5 besides the EU BiTurbo TDI ZF8; match your generation to minimize coding issues.Except for BITURBO TDI Transmissions) My transmission A6 transmission I selected is NNT code.( It does not matter what code your DSG DL501 was, it will work)​”
          Toisella sivulla (viesti #66) eurooppalainen kaveri nimeltä Rigorizni kirjoittaa: ”Firstly I'd like to point out that the ZF8 gearbox that came on the Bi Turbo TDI is 16mm shorter than the DL501 (I am not sure if this is the case for ZF8HP55 that came on other cars or the US market in general) and thus the driveshaft is 16mm longer and weights more than double compared to DL501 driveshaft. But I figured since my original driveshaft already took everything I threw at it with the DL501 it should be ok for the ZF aswell, so I had a machine shop make me a distance plate which I placed between the driveshaft and the rear diff and got longer bolts to replace the original ones which were too short with the distance plate. Please note that the DL501 driveshaft can be used without the distance plate, but when mounted that way it does not fully seat on the gearbox and there is a risk of destroying the splines on either the driveshaft or the gearbox.”
          Eli 16mm lyhyempi tippiloota euromallin bitissä. Ja kardaani painaa tuplat enempi ja myös 16mm pidempi.
          eli:
          - Tankii
          - bensalinjat
          - pumppu
          - moottori
          - putkisto
          - ecu
          - mittaristo
          - virtalukkoa uutta ei tartte varmaan ollenkaan jos lootahommassa immo disabloidaan..
          Ja sitten paljon pikkuhilua. Voisi olla mielenkiintoinen projekti kyllä. Samalla laittais RS ahtimet. Ja sit vois kyl jo laittaa rs ecu, mittaristo yms. Jos ajelis RS vakiokartalla. Pitää lisää guuglailla.
          EDIT: Tekniikanluovuttaja S6/S7 saa Saksasta halvimmillaan 14-15k€. Sellasen vois hakea ja myydä osina loput mitä ei tartte. Ja oman bittikoneen myös osina. Peruskorjatut ahtimet, rempatut kannet yms yms.
          Viimeksi muokannut Fromi; 24.6.2026, 12:33.
            Ainakin CGQB moottoreissa näyttäisi olevan solenoidi paineen ohjausta varten. Mutta siitä ilmeisesti selviää kun vain hyppää johdon irti.
              Kyselin marmorilta hintoja laakereille. Ei ne nyt kauheita ole. Periaatteessa selviää osista varmaan tonnilla. Työtä senkin edestä.
              No kattoo ny mitä tekee. Saa aivot muhia rauhassa.
                Eipä ole valitettavasti ensimmäinen biTDI (competition) moottori joka hajonnut. Tälläkin foorumilla useampi missä näin käynyt, yleensä vielä kerta laakista täys tuho.
                  Voi harmi. No kauhean kallista osien kannalta ei ole. Mutta työtä riittänee kyllä. Harrastushommana otettava. Ei kannata ihan viiden kympin firabeli-tuntihintaa laskea itelleen :D
                    Alkuperäinen kirjoittaja horch Näytä viesti
                    Edelleen mutuilen tässä lähteenä mm. Audin SSP:t.
                    BiTDI solenoidi ohjaa öljyn virtauksen määrää, ei säädä öljyn painetta (ensimmäinen kuva). EA897evossa taas säädetään öljynpainetta, siitä taulukko kuva EA897evo2 .
                    • #70
                      Kiitos! Pitää tutkia tää asia, kun Amarokeja menen katsomaan. Jahka saa Crafterin pois nurkista.
                      Siisti Crafter 2,5TDI olis tarjolla sopivasti.
                      Kerran vuoteen ruosteita fiksailtu. 2008 vuotinen, ei oo sinkittyä koria.
                      Ollut kakkosautona ja raksavehkeenä.
                      • #71
                        Tänään sain vastauksen katsarilta. Käyttövoiman vaihto ei onnistu ilman Traficomin lupaa.
                        Eli homma jatkuu agendalla korjaus loppuvuodesta, kun aikaa tekemiselle vaputuu tai sitten myynti tässä kunnossa.
                        • #72
                          Tuo käyttövoiman vaihto on herättänyt keskustelua tulkinnasta muutenkin. Siihen olisi käsittääkseni tulossa selvennys, kunhan se täsmennetty rakennuslaki joskus julkaistaan.
                          Eli, saattaa tilanne muuttua piakkoin tai sitten ei.
                          • #73
                            Lausuntopalvelussa on nähtävissä korjattu rakennemuutosmääräys, mikä oli tarkoitus julkaista 2025 kesällä, mutta ei ole näkynyt, eikä ole aikataulusta tullut uutta tiedotusta.
                            Lausuntopalvelu - Määräysluonnos Auton ja sen perävaunun rakenteen muuttaminen
                            • #74
                              Eikös jossain vaiheessa ollut niin että dieselin käyttövoiman muuttaminen etanoliksi onnistui
                              • #75
                                Joo etanoliksi onnistuu. Ja kaasuksi.
                                Mutta mitenköhän, jos on alunperin vaihtotekniikka ollut bensiini. Pitää ensiviikolla selvitellä lisää.
                                • #76
                                  Päätin tänään myydä auton viallisena. Jos ei mene kaupaksi ennen talvea, korjaan sen sitten.
                                  Osat n. 1500€ (sis. kampuran ja kiertokankien laakerit ja uudet pultit pukkeihin) ja parin viikon hommat.
                                  Tarjouksia saa esittää. Osviittaa sen verran, että bitti compet menee Nettiautosta äkkiä. Olisin voinut solmia kaupat 35k€ tästä keväällä, en malttanut kuitenkaan myydä. Jälkikäteen olis kannattanu :D
                                  Eli ei mitään 20 tonnin tarjouksia :)
                                  149tkm lasissa. Siistimpää vehjettä saat etsiä. Ja hei, Nardo grey!
                                  Viimeksi muokannut Fromi; 29.6.2026, 21:01.
                                  • #77
                                    Elämä jatkuu. Muutoksia päätökseen, ellei mene fiksusti kaupaksi niin korjaan talvella ja pidän auton :)
                                    RISU myi norsunkorvan, niin pitää kait mun sellanen sitten hake, että foorumin norsunkorvakiintiö säilyy.
                                    Se jää sitten meille kakkosautoksi. Löytyi paljon ajettu, mutta erittäin hyvin huollettu ja varusteltu. 2.0TDI neliveto CAHA moottorilla. Siitä myöhemmin oma topiccinsa. Luvassa käyttökunnostelua ja mahdollinen ylimaalaus Nardo harmaalla. Sen verran nykyinen pinta elämää nähnyt.
                                    • #78
                                      Tykkään! :P
                                      • #79
                                        Nuo Q5:n peilit, mistä tämä ”norsunkorva” nimitys on luultavasti tullut, ovat kyllä vaaralliset. Aina kurkattava sieltä yläpuolelta. Peittää ison osan näkökenttää, eikä silti hyödytä ollenkaan taakse katsoessa se suuri koko.
                                        offtopicia, mutta nyt kun +RISU linjoilla olit :D
                                        • #80
                                          Kyllä vain, isot ja harmaat oli SQ:ssa, niin norsunkorviksi minä ne ristin.
