Autona siis vm05 A6, 2,4 V6 automaatilla. Auto ns. ’’dumppaa’’ aika usein hiljaisilla nopeuksilla ja kiihdyttäessä. Pysyy käynnissä mutta veto loppuu ja kierrokset laskee noin sekunniksi tai kahdeksi, jonka jälkeen herää henkiin ja vastaa kaasuun. Osaako joku kertoa mahdollisia vikoja/aiheuttajia? johtuuko allaolevista vikakoodeista?
3 Faults Found:
000016 - Bank 1: Camshaft A (Intake)
P0010 - 008 - Position Actuator Malfunction
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 254
Reset counter: 40
Mileage: 189719 km
Time Indication: 0
Date: 2014.04.20
Time: 10:43:39
Freeze Frame:
RPM: 1152 /min
Mass Air / Rev.: 169.0 mg/str
Temperature: 39.0°C
Part Throttle
Bin. Bits: 00000000
Steering Angle: 104.61°
000032 - Bank 2: Camshaft A (Intake)
P0020 - 008 - Position Actuator Malfunction - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 34
Reset counter: 37
Mileage: 195129 km
Time Indication: 0
Date: 2014.08.13
Time: 08:52:38
Freeze Frame:
RPM: 1248 /min
Mass Air / Rev.: 174.4 mg/str
Temperature: 42.0°C
Part Throttle
Bin. Bits: 00000000
Steering Angle: 112.79°
001393 - Brake Switch (F)
P0571 - 008 - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 40
Mileage: 200905 km
Time Indication: 0
Date: 2014.11.22
Time: 13:28:00
Freeze Frame:
RPM: 1408 /min
Mass Air / Rev.: 92.7 mg/str
Temperature: 75.0°C
Idle
Load: 3.9 %
Speed: 42.0 km/h
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 40
Mileage: 189719 km
Time Indication: 0
Date: 2014.04.20
Time: 10:43:39
Freeze Frame:
RPM: 1152 /min
Temperature: 39.0°C
Part Throttle
Bin. Bits: 00000000
Freeze Frame:
Fault Priority: 2
Fault Frequency: 34
Reset counter: 37
Mileage: 195129 km
Time Indication: 0
Date: 2014.08.13
Time: 08:52:38
Freeze Frame:
RPM: 1248 /min
Temperature: 42.0°C
Part Throttle
Bin. Bits: 00000000
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 40
Mileage: 200905 km
Time Indication: 0
Date: 2014.11.22
Time: 13:28:00
Freeze Frame:
RPM: 1408 /min
Temperature: 75.0°C
Idle
Load: 3.9 %
Speed: 42.0 km/h
