Audi 1.8tq B5 -96
  • Audi 1.8tq B5 -96
    Kysyn onko monta poltinta mittatitaulussa kierrosmittarin takana.Pimeni kellon,kierrosmittarin valot .Meni pimeeksi viikon sisällä.Ensin hävisi kellon valot ja tänään kiekkamittarin valo.Onko polttimot tavan huoltoasema tavaraa,jos huomenna korjais valoja.
    Ei muuta kuin laskeskelemaan.... Eikös ne ole noita Dash panel insert illumination polttimoita, jotka valaisevat ko. kohtia?
    Kuva
    Repairing dash panel insert up to model year 00
    Assignment of lamps in dash panel insert (vehicles > 1997)
    Highline version of dash panel insert with vehicle computer
    1. Dash panel insert illumination
    ◆ 9 x 1.1 W
    2. Right turn signal warning lamp (K94)
    ◆ 1.2 W
    3. Left turn signal warning lamp (K65)
    ◆ 1.2 W
    4. Main beam warning lamp (K1)
    ◆ 1.2 W
    5. Odometer display illumination
    ◆ 1.1 W
    6. Malfunction/engine electrics warning lamp
    ◆ 1.2 W
    7. Trailer turn signal indicator warning lamp
    ◆ 1.2 W
    8. Traction Control System (TCS) warning lamp
    ◆ 1.2 W
    9. Warning lamp for side marker lamp
    ◆ 1.2 W
    10. Warning lamp for diesel glow plug system
    ◆ 1.2 W
    11. Immobiliser warning lamp
    ◆ 1.2 W
    12. CAT warning lamp
    ◆ 1.2 W
    13. Airbag warning lamp
    ◆ 1.2 W
    14. ABS warning lamp
    ◆ 1.2 W
    15. Handbrake/brake malfunction warning lamp
    ◆ 1.2 W
    16. Charge warning lamp
    ◆ 1.2 W
    17. Seat-belt warning lamp
    ◆ 1.2 W
    18. Vehicle computer illumination
    ◆ 5 x 1.1 W
    Lowline version of dash panel insert with mini-check system
    ‒ 9 x 1.1 W for VDO dash panel insert with additional instruments
    ‒ 7 x 1.1 W for VDO dash panel insert without additional instruments
    ‒ 6 x 1.1 W for Nippon Seiki dash panel insert
    Note:
    When changing bulbs for Nippon Seiki dash panel insert illumination, always use replacement bulbs with red caps.
    ◆ 1.2 W
    ◆ 1.2 W
    ◆ 1.2 W
    ◆ 1.1 W
    ◆ 1.2 W
    ◆ 1.2 W
    8. Traction control system (TCS) warning lamp
    ◆ 1.2 W
    ◆ 1.2 W
    ◆ 1.2 W
    ◆ 1.2 W
    ◆ 1.2 W
    ◆ 1.2 W
    ◆ 1.2 W
    ◆ 1.2 W
    ◆ 1.2 W
    ◆ 1.2 W
    1. 19 - Warning lamp for coolant temperature too hot
    ◆ 1.2 W
    2. 20 - Oil pressure warning lamp
    ◆ 1.2 W
    3. 21 - Warning lamp for brake malfunction
    ◆ 1.2 W
    4. 22 - Warning lamp for fuel content
    ◆ 1.2 W
