A6 tiptronic ongelma
  • A6 tiptronic ongelma
    Auto on -98 A6 avant 2.5 TDi tiptronic . Ongelma: D-vaihde päällä peruutusvalot palavat. Muuten vaihteisto toimii täysin normaalisti. Mahtaa olla joku valintakytkin rikki? Voikohan sitä korjata vai onko laitettava uusi? Paljonkohan osa maksaa? Paljonko jäsenhinta olisi osalle?
    Lue/lueta vikakoodit.
    Mikä on automaatin tyyppi (kolme kirjainta)?
    Katso täältä http://etka.auto2.ru/au/A6/1998/261/51/3319346/
    Mahdollisesti multifunction switch (asentotunnistin).
    Tarkista valojen johdot takaluukun saranan vierestä.
      Jos ei vikakoodeja, niin voisi olla magneettikin?
      The problem usually comes from the small magnet piece that is placed in the black rubber cover that moves with the shifter lever. You need to remove the chrome cover that goes around the shifter. Inside the cover there is a board that has the hall effect sensors used for TIP position. The black rubber / plastic cover around the shifter (that moves back and forth with the shifter) has a pocket (on the left side of the shifter rod) that houses a magnet(about 3x3x8 mm). All you have to do is find the magnet and put it back in place. The dealers usually replace the switch board (that sits inside the chrome shifter cover) but I bet 90% of the failures come from the magnet that comes out of its housing. It is relatively common problem if you have the car detailed and they use high pressure air to blow the dust off or use excessive pressure to clean the rubber cover.
