Kopioin vanhan kirjoitukseni, jonka löysin searchilla e21-hakusanalla ikäänkuin nopeasti:
Pitkäsen kirjoitus s2forumilta:
Näinollen e21 315 tuki on varmaan parempi vaihtoehto.
Center mount from a e21 BMW 315 is a almost straight fit. You may have to file the bolt holes a bit bigger but that's it. The BMW part has same dimensions as the original, the propshaft even lined up correctly without doing any adjustments from the original set up.
BMW part number for that center mount is 26 11 1 206 502 or Febi part # 05196. The Febi part was about 35euros here in Finland.
I know this because I did a propshaft overhaul in november. I changed that center mount, rear cv joint and the middle u-joint. Before the overhaul my car had an annoing little shake when moving but now it's gone and my propshaft is like new again.
