A6 4F ESP valopalaa ja vakkari ei pelaa. Vika löytyi !!!
  • A6 4F ESP valopalaa ja vakkari ei pelaa. Vika löytyi !!!
    Elikkäs ESP valo syttyy aikalailla heti startissa, sitten saatta kadota hetkeksi vain palatakseen takaisin.
    Samalla ilmestyy teksti ESP fault, see owners manual.
    Alla osin referoituna vikalista...
    Koitin hakua ja googlea, mutta ajattelin kuiten laittaa tämän tänne, josko joku osaisi antaa vihjettä mistä alan kaivamaan.
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4F0 910 401 A HW: 4F0 907 401 B
    Component: 3.0L V6TDI G000AG 0010
    Revision: --H01--- Serial number:
    Coding: 0011372
    Shop #: WSC 31000 205 66410
    VCID: 1A3B34E3D56A62CE7A7-804F
    006464 - Powertrain Databus
    P1940 - 001 - Missing Message from Control Module for Battery Monitoring - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 0
    Fault Frequency: 254
    Reset counter: 255
    Mileage: 221295 km
    Time Indication: 0
    Date: 2018.02.21
    Time: 10:02:24
    Freeze Frame:
    RPM: 1134 /min
    Torque: 187.2 Nm
    Speed: 0.0 km/h
    Duty Cycle: 13.9 %
    Voltage: 13.68 V
    (no units): 1224.0
    005715 - Please check DTC Memory of ABS Controller
    P1653 - 002 - - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 0
    Fault Frequency: 199
    Reset counter: 255
    Mileage: 221295 km
    Time Indication: 0
    Date: 2018.02.21
    Time: 10:02:26
    Freeze Frame:
    RPM: 1134 /min
    Torque: 175.5 Nm
    Speed: 1.1 km/h
    Duty Cycle: 12.0 %
    Voltage: 13.60 V
    Bin. Bits: 00101100
    Torque: 312.0 Nm
    005785 - Powertrain Data Bus
    P1699 - 001 - Missing Message from Steering Wheel Electronics - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Reset counter: 255
    Mileage: 221296 km
    Time Indication: 0
    Date: 2018.02.21
    Time: 10:03:13
    Freeze Frame:
    RPM: 1848 /min
    Torque: 249.6 Nm
    Speed: 50.4 km/h
    Duty Cycle: 29.9 %
    Voltage: 13.38 V
    Bin. Bits: 00101100
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4F0 910 156 H HW: 09L 927 156
    Component: AG6 09L 3.0lTDI RdW 0100
    Revision: --H01--- Serial number: 0091696
    Coding: 0000001
    Shop #: WSC 02331 785 00200
    VCID: 285F1E2B9B06C05EFC3-807D
    2 Faults Found:
    18265 - Load Signal
    P1857 - 000 - Error Message from ECU - Intermittent
    Freeze Frame:
    Fault Status: 00110000
    Fault Priority: 0
    Reset counter: 40
    Mileage: 221295 km
    Time Indication: 0
    Date: 2018.02.21
    Time: 10:02:25
    Freeze Frame:
    RPM: 1120 /min
    RPM: 128 /min
    RPM: 32 /min
    (no units): 7.0
    (no units): 41.0
    Temperature: -11.0°C
    T.B. Angle: 13.3°
    18275 - Powertrain Data Bus
    P1867 - 001 - Missing Message from Steering Wheel (J527) - Intermittent
    Freeze Frame:
    Fault Status: 00110001
    Fault Priority: 0
    Reset counter: 40
    Mileage: 221296 km
    Time Indication: 0
    Date: 2018.02.21
    Time: 10:03:13
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
    Component: ESP 8.0 quattro H03 0090
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0037256
    Shop #: WSC 45896 141 14353
    VCID: 2D51EF3FB4E4E5760F5-8078
    18265 - Load Signal
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 3
    Fault Frequency: 202
    Reset counter: 175
    Mileage: 221295 km
    Time Indication: 0
    Date: 2018.02.21
    Time: 10:02:24
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x4082
    Hex Value: 0x0028
    Hex Value: 0x01A9
    Hex Value: 0x00FF
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 HW: 4F0 907 279
    Component: ILM Fahrer H14 0080
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0012121
    Shop #: WSC 02335 785 00200
    VCID: E6C3D013D192962E8EF-80B3
    Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
    Component: Wischer AudiC6 H05 0150
    Coding: 00062736
    Shop #: WSC 02335
    Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH10 0050
    Coding: 00141886
    Shop #: WSC 02335
    2 Faults Found:
    01336 - Data Bus for Comfort System
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 1
    Fault Frequency: 45
    Reset counter: 174
    Mileage: 221312 km
    Time Indication: 0
    Date: 2018.02.21
    Time: 10:14:00
    01498 - Bulb for Parking Lamps; Right (M3)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 2
    Fault Frequency: 179
    Reset counter: 174
    Mileage: 217140 km
    Time Indication: 0
    Date: 2017.12.10
    Time: 15:04:00
    Address 19: CAN Gateway Labels: 4F0-910-468.lbl
    Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
    Component: Gateway H09 0030
    Revision: 09 Serial number: 080080521000B2
    Coding: EDFE73C61B1104
    Shop #: WSC 02325 785 00200
    VCID: 275D1D179618CF26F59-8072
    Freeze Frame:
    Fault Priority: 1
    Reset counter: 175
    Mileage: 221295 km
    Time Indication: 0
    Date: 2018.02.21
    Time: 10:02:14
    00456 - Control Module for Access and Start Control (J518)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 48
    Reset counter: 175
    Mileage: 221432 km
    Time Indication: 0
    Date: 2018.02.21
    Time: 11:39:22
    00474 - Control Module for Immobilizer
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 48
    Reset counter: 175
    Mileage: 221432 km
    Time Indication: 0
    Date: 2018.02.21
    Time: 11:39:22
    00466 - Control Module for Steering Column Electronics (J527)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 38
    Reset counter: 174
    Mileage: 221432 km
    Time Indication: 0
    Date: 2018.02.21
    Time: 11:40:45
    01320 - Control Module for Climatronic (J255)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 54
    Reset counter: 175
    Mileage: 221432 km
    Time Indication: 0
    Date: 2018.02.21
    Time: 11:41:22
    Viimeksi muokannut mafra; 8.3.2018, 18:17. Perustelu: vika löytyi
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280
    Component: ILM Beifahrer H09 0050
    Revision: Serial number: 00000000040650
    Coding: 0001003
    Shop #: WSC 02323 785 00200
    VCID: DEB3F8F309C2CEEE46F-808B
    5 Faults Found:
    02072 - Control Module for Energy Management (J644)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 23
    Reset counter: 174
    Mileage: 221576 km
    Time Indication: 0
    Date: 2018.02.21
    Time: 15:20:00
    Freeze Frame:
    Voltage: 12.100 V
    Temperature: 9.0°C
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 56
    Reset counter: 175
    Mileage: 221432 km
    Time Indication: 0
    Date: 2018.02.21
    Time: 11:39:00
    Freeze Frame:
    Voltage: 12.600 V
    Temperature: -5.0°C
    01299 - Diagnostic Interface for Data Bus (J533)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 173
    Mileage: 262140 km
    Time Indication: 0
    Date: 2018.07.10
    Time: 20:19:00
    Freeze Frame:
    Voltage: 11.700 V
    Temperature: 12.0°C
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 70
    Reset counter: 175
    Mileage: 221432 km
    Time Indication: 0
    Date: 2018.02.21
    Time: 11:41:00
    Freeze Frame:
    Voltage: 12.300 V
    Temperature: 20.0°C
    02095 - Component Protection Active
    000 - - - Intermittent
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 20
    Reset counter: 174
    Mileage: 221300 km
    Time Indication: 0
    Date: 2018.02.21
    Time: 10:09:00
    Freeze Frame:
    Voltage: 13.500 V
    Temperature: -15.0°C
    Address 55: Xenon Range Labels: 8P0-907-357.lbl
    Part No: 8P0 907 357 C
    Component: Dynamische LWR H01 0010
    Coding: 0000003
    VCID: 3A7BD46375AA42CE9A7-806F
    1 Fault Found:
    00070 - Starting Battery Voltage
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 0
    Mileage: 8 km
    Time Indication: 0
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
    Component: ENERGIEMANAGER H12 0490
    Revision: 00000000 Serial number: 00000000017580
    VCID: 23450907E2202306A91-8076
    Subsystem 1 - Part No: 000 915 105 DK
    Component: von VA0 301029T0VY
    Coding: 303030393135313035444B56413033303130323954305659
    Shop #: WSC 00000 384 00290
    5 Faults Found:
    02276 - Quiescent Current Stage 5
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 8
    Reset counter: 255
    Mileage: 218748 km
    Time Indication: 0
    Date: 2018.01.09
    Time: 07:47:11
    00532 - Supply Voltage B+
    001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 167
    Mileage: 221584 km
    Time Indication: 0
    Date: 2018.02.22
    Time: 02:16:58
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 32
    Reset counter: 175
    Mileage: 221432 km
    Time Indication: 0
    Date: 2018.02.21
    Time: 11:41:21
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 12
    Reset counter: 173
    Mileage: 221432 km
    Time Indication: 0
    Date: 2018.02.21
    Time: 11:39:21
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 122
    Reset counter: 175
    Mileage: 221301 km
    Time Indication: 0
    Date: 2018.02.21
    Time: 10:08:19
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4F0 910 283 A HW: 4F0 919 283 A
    Component: Parkhilfe 8-Kan H12 0030
    Revision: --.--.-- Serial number: 11820501501919
    Coding: 0011006
    Shop #: WSC 12345 123 12345
    VCID: 224B0C03FD3A2A0EA27-8077
    5 Faults Found:
    01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 66
    Reset counter: 152
    Mileage: 193271 km
    Time Indication: 0
    Date: 2016.09.01
    Time: 08:29:47
    01543 - Parking Aid Warning Chime (H15)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 99
    Mileage: 193271 km
    Time Indication: 0
    Date: 2016.09.01
    Time: 08:29:46
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 8
    Reset counter: 174
    Mileage: 221576 km
    Time Indication: 0
    Date: 2018.02.21
    Time: 15:11:18
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 36
    Reset counter: 175
    Mileage: 221432 km
    Time Indication: 0
    Date: 2018.02.21
    Time: 11:39:22
    01517 - Control Module for Trailer/Towing Sensor (J345)
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 4
    Fault Frequency: 47
    Reset counter: 135
    Mileage: 221295 km
    Time Indication: 0
    Date: 2018.02.21
    Time: 10:02:08
      Tuossa vikakoodeja jeesustellessa huomasin, että vikavalo kyllä syttyy vaikka auto ei ole käynnissä ja palaa kuittailujen jälkeen takaisin.
        Kommunikaatio-ongelmia, mutta juurisyyksi veikkaisin akun kyykkäystä.
          Eka helppo vaihotehto on bootata kaikki laitteet käyttämällä akku irti. Osa alijännitteestä johtuvista vioista ei suostu kuittaantumaan ilman virtojen katkaisua.
            Täältä ääni myös patterille. Onko milloin uusittu?
              Pitääpä testailla tuo akun irroitus.
              Oisko pari vuotta ollu tuo nykyinen...
              Pääsee aina näin talvisin välillä vähiin tuo akun lataus ja startissa sitte käy aika heikoilla jos starttaa lainkaan tai siis käynnistyy.
              Muutenki vähän raskas soutuinen käynnistymään, jos ei ole ollu roikassa, niin turha edes yrittää pakkasella, eikä johdu akusta se kylläkään.
                Miinus kaapeli irti jonkun aikaa ja tosiaan ESP lakkasi hälyttelemästä.
                Akku näytti muuten olevan vuoden vanha 100Ah exide.
