Onko mahdollista että höyrystin on vaihtokunnossa jos puhallin pöläytti hyttiin kylmän höyrypilven? Muutenkaan ne kylmäaineet eivät pysyneet ko pari viikkoa. Konehuoneen puolella ei ollut mitään vuotoja järjestelmässä. Jos höyrrystin pitää vaihtaa niin onko kojelaudan irroitus edessä?
S2:n kylmäaineet ohjaamoon
UrS4: ssa korjausoppaan mukaan höyrystin (evaporator) erkanee korista näin:
Koodi:Evaporator housing, removing and installing - Discharge A/C refrigerant system. - Remove glove compartment. - Remove four bolts from evaporator cover. - Remove plenum tray. - Disconnect refrigerant lines to evaporator. - Plug all open line connections. - Disconnect all connections between evaporator housing and vehicle. - Remove evaporator housing. Note: The evaporator housing cannot be disassembled and must be replaced as an assembly. Install in reverse order of removal noting the following: - Replace seal between vehicle and evaporator housing. - Replace all O-rings and properly torque connections. - Insert water drain hose through opening in plenum, route hose straight and kink-free, ensure hose connections are tight and sealed. - Check water drain valve for proper operation, clean any dirt, wax or undercoating from valve flap. Valve flap must close. - After installation, ensure there are no air leaks around housing.
